TD 366 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2012, 02:23 PM
TD 366 timing
I have a Tall deck 366 in my 86 Chevy SWB 2 wheel drive and when i first got it it had a GM HEI in it with no vacuum advance so i pulled off the cap and say that there was a spot for one it just had a plastic thing screwed in where the advance can would go so i pulled another GM HEI off the shelf and took the advance can off and put it on the one it the truck you can guess it ran like **** with the timing out of order so i set it at 8* base timing with it warm and played with the carb a lil and it had a pretty good bog or stumble off idle and at part throttle.
Its a some what stock TD 366
Headers
Performer 2.0 intake
650 carter afb competition series
GM HEI
TH400 trans
I run 87 octane gas maybe 93 if im in the mood wheres my stumble/bog coming form? and how do i go about setting the idle air on the carter with out a vacuum gauge could that be my problem?
Old 12-28-2012, 07:21 PM
techinspector1's Avatar
Wiki Edits: 326
The Edelbrock Performer and Thunder series carburetors were patterned after the Carter AFB, so follow this Owner's Manual to tune your carb....
http://www.edelbrock.com/automotive_...ers_manual.pdf
350 or 366???? jrowe94 Hotrodding Basics 11 01-06-2012 01:58 PM
sbc 366 American Muscle Engine 3 01-12-2010 10:02 PM
366 chevy_truck77 Hotrodding Basics 11 10-03-2009 08:10 PM
not a 427 its a 366 64r1 Engine 5 11-15-2008 03:25 PM
366 or 350? 1977chevyproject Engine 22 12-31-2007 02:14 PM
