teapot secondary flooding - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2012, 11:12 AM
Hi Guys,need help on a 56 holly teapot problem. The carb was rebuilt .After install it would start and barely idle with fuel running in the secondaries and the plates were closed. Installed a regulator on the pump and problem changed to flooding after wide open throttle With gas running into the secondaries and the plates in closed position. Leave it sit and the gas drains out then the cycle stars over. Let it idle, its OK, then give it throttle and manually open secondaries for a second and the fuel won't start flowing into the secondaries. Fuel pressure sitting at about 3 Lbs. Help John
Old 05-14-2012, 03:48 PM
Irelands child's Avatar
John - is there a reason that you need to keep this dog of a carb? There is a reason that many Ford owners called it a 'towering inferno'. A Carter WCFB will bolt directly in its place or another choice, a '57 intake with a 'square bore' which a Holley or Edelbrock can then be used. Of course there are after market intakes. If you need really that carb for authenticity/matching numbers, then the normal things need to be checked - float level a AND drop(seldom checked, I've found). Next and my long term recollection was that there are 2-3 ball check valves in these carbs, and at least one that has a brass weight holding the ball in place - are they all in their correct place or even there? As far as drain back - some might be after boil from engine heat as current gas, 10-15% ethanol boils at a lower temperature. Fuel pressure, 5-6 pounds would be my guesstimate for closer to normal
Old 05-14-2012, 05:16 PM
Thanks for the reply, and yes I have heard a lot of stories about this carb. Will look for a WCFB, Hope it will fit and I don't have a height problem with the hood clearence on the 56 tbird. After I read your response I thought I should have metioned that it seems to me that after the secondaries are opened and then closed and the fuel keeps running out of the secondaries even with motor off, that it appears to be siphoning the fuel out of the bowl somewhat like a hose in a gas tank. Yes I checked for the 2 balls in the two fuel passages. don't see any weight or springs showing in the drawing. Onced again thanks for the response and info. You guys have always answered my questions. I have told my wife I may head to Arizona and look for a 57 and parts like you mentioned. JP
Old 05-15-2012, 10:24 AM
tea pot siphoning
To Irelands child and all. Siphoning of tea pot issue solved. Inspected high speed secondary air bleeds and found one partially closed and the second totally closed. Cleaned both, problem solved. JP
Old 05-15-2012, 04:53 PM
Glad that you found a quick fix. Why not keep your options open though for a more up to date intake and carb and if the issue reappears (and historically with those carbs, it probably will) then you can make a change which will help performance and might even improve your gas mileage.
Old 05-16-2012, 02:27 PM
I plan on doing just that, and save the old tech parts for a buyer who wants period correct. Thanks JP
holley teapot carbs mxer898 Hotrodding Basics 1 03-08-2010 01:18 PM
Holley 750 Vacuum secondary flooding at WOT iambigperm Engine 7 05-11-2009 08:29 AM
Flooding KeithB123 Engine 8 01-10-2007 09:51 PM
flooding TannerH Engine 4 08-31-2004 02:45 AM
Flooding? hcker2000 Engine 6 03-12-2004 06:52 PM
