tear down?
Im taking my fenders off my truck to clean up the underside and the inner fenders the problem im having is taking the bolts off. I have one side held on by carriage bolts but they don't fit right in the holes and spin when you try to lossen them. I could try to cut them off or grind them off but i dont think it will be that easy. Every thing is pretty rusty and in some areas there is a build up of crude, not sure what it is, it looks like harden tar and mud and stuff like that. I chiped some off but some wont come off so i tryed a grinder and it seems to work but if i grind in the areas i need to, around the bolts, i wont be able to use a wrench and then ill have to find a way to remove the bolt. Any ideas would be great.
ill have to try the wire brush, just picked up a cutt off wheel tonight and havent gotten a chance to try it yet
If you need to remove a carriage bolt that spins in the hole,if it is accessible ,clean the head and weld a nut to it.I had to do this to some bolts holding the bed on on an old Ford truck.It worked great. Hope this helps.
ill give it a try and ill get some pics when i can. thanks
| 51 FORD V-8 tear down | ed keeley | Body - Exterior | 4 | 06-18-2006 10:51 PM |
| 305 tear down and stuff.... what should I do? | Drew's 57 | Engine | 13 | 02-22-2006 04:32 PM |
| Today... I shed a tear! | chevyluvnpuppy | Hotrodders' Lounge | 6 | 08-01-2003 11:22 AM |
| I think I'll tear into the Hemi! | HemmiGremmie | Hotrodders' Lounge | 4 | 08-26-2002 01:15 PM |
| Tear down 1st rebuild and rebuild again help.... | HemmiGremmie | Engine | 10 | 08-20-2002 10:29 AM |
