tear down - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2003, 07:21 PM
Post tear down
I recently built a sb chevy 350 with a holley systemax 2 setup, thats with the aluminum heads...., well my distributor gear wasnt meshing with my cam, my fault, that i didnt check the gear mesh. so now im tearing the motor down, and checking the bearings and everything, another thing i wanted to check was the head gaskets, the motor only had about 150 miles on it, and i want to know what to look for to see if my head gaskets were leaking. i was getting moisture in my valve covers, but i have been told that new motors can do that.
Old 04-17-2003, 07:36 PM
4 Jaw Chuck's Avatar
Post
There will be a witness mark left on the machined surfaces of the heads and the block where the gasket "imprinted" itself. If there are any gaps or obvious leak marks that would be a clue, sounds like your moisture problem is normal but it can't hurt to check. Coolant in the oil will be obvious.
— Han Solo
Old 04-17-2003, 07:56 PM
Post
no as for my cam, the cam is made alot tougher than the distributor i have heard, so im hoping my cam is ok, is that true abotu the cam gear being stronger than the dist gear
Old 04-17-2003, 09:51 PM
Post
Harder not stronger...yes. Wearing metal pairs work best if one is softer than the other, always make the easily replaceable part softer (hence the distributor gear being softer).
— Han Solo
Old 04-18-2003, 04:12 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
You could be getting water past the head bolt's/stud's on the one's that go into the water jacket in the block if you did not use a sealer.
Luv the smell of NITRO in the morning.
