Tearing down heads (350 chevy) 1968 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 05:57 PM
I plan on rebuilding complete eng. My question is, is it necessary to mark puahrods etc. not sure.if I will put.it new.etc. Also intake is cast original if it.s.good mo need.to.swap out correct, any suggestions would be appreciated, Dana
Old 04-11-2012, 06:39 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It depends IMHO.
If you are doing a complete re-build then you will be installing a new cam and lifters correct ? Is this just a basic re-build or are you planning on added HP ?
What parts do you have or are planning on getting for the build ?
Really need more info on the use of the engine. IMHO
Cole
Old 04-11-2012, 08:07 PM
Motor
Strickly stock or as close to it. my heads, should I replace every part just to replace or not?
Old 04-11-2012, 08:09 PM
Yes new cam amd lifters, any suggestions on brand of parts.
Old 04-12-2012, 07:01 AM
You fail to mention which heads you have. No really relevant, but "nice to know". If all the parts are "original", I would certainly replace the valves, springs and locks. The retainers are pretty tough. Not expensive, though.
That era of small block is known for guide wear. Be sure a competent machine shop inspects the heads thoroughly. A "valve job" IS called for.
Jim
Old 04-12-2012, 07:22 AM
BOBCRMAN@aol.com's Avatar
If these are 1968 heads. As mentioned, You will have to check the guides and if this is to be a "working" driver engine. Hard exhaust seats will have to be installed. Rotators installed, with springs to compliment the rotators. Probably cheaper to get some late seventies early eighties heads.
Old 04-12-2012, 04:33 PM
eloc431962's Avatar
Wiki Edits: 37
X2 Bob
Cole
Things to look for when tearing down heads Tubbed357 Engine 4 01-28-2010 09:17 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
1968 2.02 Heads to an 80's 350 Block? hotrodron_04 Engine 1 05-05-2007 09:23 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
1968-69 327 1.72/1.5 Heads on 71 350 brennecke Engine 5 04-10-2002 08:56 PM
