tecgt ecu - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2011, 08:40 AM
tecgt ecu
Hi' Has anyone got a good bin file for a tecgt ignition and efi system with phased injectors and first fuel tpi style injection system my engine is a 383sbc afr210cnc heads with 9.5:1 comp. comp cams cs 242/248-112 hyd.roller w/16deg @ 850 38deg@3000rpm it had a hollley pulling 12"vac @ 1000rpm using a edelbrock airgap. pulled 535hp @5800 and 520ft-lb torque@4300rpm. I am also using dfu waste spark ignition. I need some good base settings as i am struggling with rich mixture problems.
