Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tech 1 Scan Tool
Old 03-30-2011, 10:50 AM
matt167 matt167 is offline
Wiki Edits: 31
Tech 1 is the only scanner that can do the GM ABS brake bleeds. If that is what the OP is looking to do. then the Tech 1 is the only solution. For everything else, there are a lot of cheaper alternatives for OBD-I
