Technique of broken bolt removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2012, 03:50 AM
New Member
Any body can help me in finding the company that can offer services related tot the removal of broken bolts and metal disintegration? I require it for my companies customers.
Old 09-17-2012, 07:56 AM
delawarebill's Avatar
it might help IF....
u posted where u'r from ????????????????????????????????
or the area u'r looking for... ???????????????????????????
Old 09-17-2012, 11:55 PM
New Member
I am searching for the US location.
Old 09-18-2012, 10:47 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Your question makes no sense to me. Where in the US are you looking? Any competent person, mechanic and machine shop can remove most broken bolts and screws unless it's in your Rolex.
Old 09-20-2012, 01:49 PM
put up or shut up
just use a center punch and punch it dead square in the middle. Use a 1/8" bit for a pilot hole, then use a 3/32", then finally the size you want for your bolt. I like to take the bolt that belongs in the threads where the broken bolt is, then find a nut that fits it. Then you take the biggest bit you can find that fits thru the nut and drill out the rest of the bolt with that bit. Last retap the hole with the right sized tap for the original bolt and it's like nothing ever happened. It doesn't work all the time and its success hinges on how well you center your punch mark.
Old 11-02-2012, 02:05 AM
Re: Technique of broken bolt removal
Depending on the bolt, its size, what it's broken off in, and is/was it seized when broken off, there are several ways to get it done; My first choise is to carefully center punch the bolt use a reverse twist(left hand twist) drill, usually as they break through they will catch and turn out the bolt. I know it sounds funny but they actually do make left hand twist drills in a variety of sizes, You can get them at most good machinery or tool sales stores.
Failing that, I try an easy out, if that fails even after trying heating the material the bolt is broken off in to loosen it I usually try drilling it out as close to the thread size as I can and use the correct tap to get the remaining threads out or a torch to get the remaining threads out by heating them very hot then use a pick to remove them before running a tap through the threads.
Last resort is to find an automotive machine shop (Engine rebuilder) most will have a machine that can burn out the bolt...
Old 11-02-2012, 05:28 AM
Look up machine shop in yellow pages problem solved
Old 11-02-2012, 06:18 AM
poncho62's Avatar
Wiki Edits: 5
Why do you want an American machine shop when your IP shows you are India?????
Old 11-02-2012, 06:45 AM
Last journal entry: was hoping for better than this
maybe he's a sales guy for a surplier to the usa chain..
tons of stuff seems to be coming from china and india now..
Old 11-02-2012, 11:58 AM
If you are talking about EDM (electrical discharge machining) then Google is your friend.
Old 11-02-2012, 12:58 PM
johnnyg's Avatar
hold my beer and watch this!
Drill a hole in the bolt and then use an easy out.
Old 11-02-2012, 02:14 PM
Use of the term "metal disintegration" leads me to believe he's talking about EDM.
Broken Dipstick Tube Removal smokey626 Engine 9 02-27-2009 02:50 AM
Broken Bolt Removal 74_Chevy General Rodding Tech 10 12-26-2005 07:55 PM
Broken bolt blacklotus Hotrodding Basics 7 12-30-2004 10:14 AM
broken rocker stud removal smokin 69 Engine 2 11-04-2003 01:53 PM
broken rocker stud removal smokin 69 Engine 4 10-30-2003 07:11 PM
