Teenage 377 Build for '72 SS - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2008, 12:10 PM
Ok, I'm fairly new here on the site. I've been around for a while reading, trying to learn as much as possible. Being that I'm only 19 years old my funds and knowledge is fairly limited. I have always been into older cars, never could get into the ricer scene. I have had my Chevelle since I was about 9 years old, and while it runs good and looks good I have decided that it is time to have a bit of fun with the car. A couple months ago I decided to begin working on a new motor. Here are the specs.
Block: 400 sbc, .030., zero decked, plate honed, main girdle, all the goodies.
Crank: 3.48 stoke forged 4130 scat crank
Rods: Eagle 6'' forged I beams
Pistons: Keith Black forged 9:1 flat tops, massive valve reliefs (not sure on exacts) the thin 377 ones
Heads: For now 462 cast double humps, ferrea valves 2.02/1.6, comp valve springs matched to cam, arp screw in studs, comp gold 1.6 rockers, full porting, 62cc combustion chambers; eventually will replace with a set of afr's or dart pro 1s
Cam: Comp 4/7 firing swap solid flat tappet. .520/.540 lift, 244/252 duration, 110 lobe sep, plasma nitride deal. using lifter pn 813-16
Carb: Used Barry Grant mighty demon 850. I rebuilt the carb, powder coated it, and a good friend of mine from the machine shop is going to help me tune it to the car.
Nitrous works fogger plate kit, jets for 100-300 shot. Prob wont spray for a while, but a 150-200 shot when I do. Everyone at Hi Tech says the motor will love a little N2O, but i'm going to be fairly conservative.
Also have the comp recommended pushrods, stud girdle, the best bearings and gaskets that my machine shop could get, and a old set of hooker headers that I refinished.
That is all I have right now, I'm working this a piece at a time. The motor will be done by feb 1st. Future parts include:
Weiland Team G high rise single plane intake
Summit/Melling oil pan and pump combo
MSD pro billit distributor and full MSD ignition system
Transpro Dual Core Alum Rad
TCI 3500 stall torque converter
Desktop Dyno shows me a 519hp at 7000 rpm and 510 ft/lbs at 4000 rpm with an 11.14:1 comp ratio with the 462s. This is a street car, but wont be driven very often and will see moderate track use. I am working 2 jobs, one at Autozone where I am a part time manager and at Hi Tech, the machine shop helping with the build.
This project is my baby, I am putting my life into it. I am even using my part of it for my school projects (precision machine major). Sorry about the rant, I am just very excited about my build and I'm getting very close to final assembly. I love doing buildups like this, and since starting this motor it has given me a chance to turn it into a career. Working with my shop has got my name out to some of the big wigs in this area.
Again sorry about the rant, please give all info you can for me. Good or Bad, any help would be appreciated. I am all about info and the small details, I have read every tech article I can and applied as much as I possibly could.
Thanks in advance, Brad
Old 12-15-2008, 01:36 PM
Banned
Well, I'm sure you've already heard this, but better heads would really help that engine shine. A narrower LSA would help those stocker eahds, but with the AFR's or Dart's the 110 would be about right. Overall it looks like a great combo.
Oh, and your compression looks a little high for those heads- maybe not pump gas compatible- again AFR's would help you in that dept.
Old 12-15-2008, 01:45 PM
Nice build. I considered a 377 for mine, they are high revving engines, should be fun.
If the heads do become an issue and budget is a problem, the Brodix IKs are great heads for under $1000. Probably the best budget head made. You can save yourself $500.
I have the Pro1s, so I'm biased.
Old 12-15-2008, 03:40 PM
DoubleVision's Avatar
No offense, but I certainly hope you know how to drive and handle this much power at the level you speak of building. I would have a roll cage installed along with a 5 point seat belt. I only say this because safety comes first, and it`s hard to enjoy your chevelle dead or in a wheel chair.
Old 12-15-2008, 04:02 PM
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 51
I'm guessin you are getting machine work done cheap. Lucky you.
Hopefully all works out good.
Just wondering why you went with the 4/7 swap
I mean I hear some guys say they make more power, some guys say they don't. Either way it isn't much and I always considered it not worth doing on a street car where a few HP isn't going to be that big of a deal.
Just curious?
BiG WHiskey
Old 12-15-2008, 04:27 PM
Hey, btw....
A good friend of mine started out just like you. He went to college and studied to be an areonautical engineer, he designed military aircraft. He lives in Iowa and now makes his living building $50-70,000 sprint car motors, as well as street builds. He's worked with guys like Sonny Lenard.
Stick with it, you can be doing the same soon. He's int he national guard till April. If you want to talk to him when he gets back, let me know. He's a great builder, brilliant guy, and may be able to help you out if this is something you want to do full time.
Good luck with the build.
Old 12-15-2008, 05:22 PM
Funds fairly limited huh? Damn, I'd like to have the amount you called 'limited'. Eitherway, looks mad cool. I dig the 4-7 swap. I don't know if you'll want the giggle gas right off the bat because that thing should get it on. Defenitely get some heads- unless those 462's have had a good hand porting them. A good set of heads will make that thing shine.
Old 12-15-2008, 08:03 PM
The limited funds comes from the fact that well, I have to save to but what I need. I started this build in July, and I'm just now getting the long block together. U know, buy cam one week, next paycheck get the block bored. Had to save 4 weeks to buy the pistons. U know how it goes. As for cheap machine work.... I do all the shop dirty work to pay for what machining I don't feel comfortable doing myself. I have a good relationship with the shop owner (he used to race with my dad) therefore its like i'm his apprentice.
I went with the 4/7 swap due to the harmonics benefits. Since I build peak power around 7000 rpm, my shift point should be about 7200 with my rev limiter set at 7500. Even though I spent hours perfecting the balance job and plan on buying the best dampener I can afford there is still going to be that chance of damaging vibrations. I've talked to a few people who have run those cams, and they firmly believe that it can help save a high revving motor, and well longevity is the key. Whats the point of having power, if you always break something.
And don't worry double vision, i'm no stranger to a fast car. I have been racing since I was 11 in jr dragsters, then I moved up to my dad's big block powered '51 chevy pickup (guessing over 600 hp, no pump gas 50/50 mix) which I also drove on the street for special occasions. And I can hold my Dad's new toy between the lines. Its a '49 F1 roadster powered by a stout 355, around 450hp. 3 People can actually lift the *** end of this thing off the ground, and with .373 posi things can get a little sketchy. Also since a good friend of mine was killed street racing when we were 17 I've slowed down a lot, except for at the track. And the cage should be finished by the end of the week.
BTW, the 462s have hours of quality hand port time. They are as smooth as possible, every edge cut down, basically on par with a World Sportsman 2. Exhaust side and combustion chambers polished to a mirror finish, and I left a bead blasted finish on the intake to help with fuel atomization.
Old 12-15-2008, 10:25 PM
I hear you on the savings... I remember those days... (don't take any offense to my next statement- it's just what I did) living with mom and dad, no bills except car insurance and gas (cell phones weren't really on the 'scene' in 98) so every cent I earned went to the bottomless 'engine fund'. I had my eye on a set of the 'newly released' GMPP FastBurn heads. Never got to buy them- college came.
Anywho, enjoy it while you can before mortgages and kids and etc,etc,etc...comes along.
4/7 swap, yes and supposedly some cylinders get more fuel since the carb/piston signal is better. BUT this can be argued like rod ratio- If I were you, I would have bought the same cam (maybe bigger though - shifting at 7,500 gonna take some duration for that 406)
As long as your machine work is good and you have a good balancer I wouldn't worry about bad harmonics and besides it's V-8- your gonna have that.
Hell leave the 462's on there then- I assume the dude porting them knew what was going on since your work at a quasi- race automotive machine shop.
Old 12-16-2008, 05:05 PM
Wiki Edits: 51
I never really knew there was that much advantage to the harmonics of the 4/7 swap.
Fair Enough
BiG WHiskey
Old 12-16-2008, 05:46 PM
RippinRon's Avatar
I think at 7500rpm he will have way more problems then harmonics.
Old 12-16-2008, 06:31 PM
Old'n'young
*********************** I have a 302 im buliding up and only have old power pack heads to work with, compression is atleast 13:1 i need to get a better combo
Old 12-17-2008, 02:22 PM
Whats the problem with 7500 in a 377?As long as the valve train is up to it his build looks plenty capable of that.
Old 12-17-2008, 02:29 PM
Banned
Well there is the issue of the block cracking... but other tahn that it looks fine. 7500 RPM is a lot to ask fo a stock 400 block. And I know people go over it all the time, but people also break them all the time.
Old 12-17-2008, 02:56 PM
Many of the sprint car (or is it dirt track I can't remember) motors my friend builds use stock 400 blocks, and run 8000 RPMs fairly consistently and fairly reliably ,it's typically not the block that gives out.
377 stroker Mustangsaly Engine 49 10-05-2012 01:11 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
CMC '34 Coupe 1992 Build ffas23 Hotrodders' Lounge 11 12-04-2008 12:32 AM
377 Build up help SBC S-10 Engine 13 07-03-2005 07:33 PM
