Teflon Braided Fuel line - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2013, 09:35 PM
Problem, Bought some 3/8 teflon steel braided fuel line, Went to the local speed shop they gave me 6an connectors. The inner teflon line is bigger then the compression ring ect. What the heck.
Old 07-01-2013, 12:01 PM
evolvo's Avatar
Heathen
SS braided fuel line is normally rubber lined. I believe that SS Teflon lined is used for AC or power steering. Can you post up the page of the catalog where you bought your line?
Old 07-01-2013, 12:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In the past I had (twice) problems associated w/using different brands of line and fittings. I now always use the same brand of hose AND fittings to avoid fitment issues like what you're having.
Old 07-01-2013, 12:55 PM
I went with teflon line braided for Superior flow and no vapor seepage. the line I have is excellent.Pirtek Fluid Systems - Specialists in Hydraulic and Industrial Hose, Hose Fittings & Accessories
Found connectors-industial
Old 07-01-2013, 01:42 PM
Where did you get 3/8"? The AN numbering is the inside diameter of the EQUIVALENT hard line, so you can't just measure the OD of a braided line. Most teflon line is either -3 or -4. The larger sizes are used in aerospace applications, but are not common in automotive use.
Old 07-01-2013, 02:29 PM
Its on ebay under Teflon fuel line.
Guys at the speed shop thought my 13 ft length cost About 4 times what I paid for it. 5$ ft.
This stuff has the clear coating.
Old 07-02-2013, 02:15 PM
Last journal entry: 50 Ply wagon
If you bought 3/8" line you need -8 AN fittings. The -6 are for 5/16 line.
Old 07-02-2013, 02:22 PM
Well that's socal speedshop for ya. I brought in the line they sold me 6an's
I just returned them. The hose supplier said just to used high pressure hose clamps right over the braid. I did so and it works. So I will just leave it like that for now.
Thanks for reply
how to cut braided fuel line? Longboard Hotrodding Basics 27 01-11-2017 01:41 PM
Rust on braided line myrtle71 General Rodding Tech 5 04-18-2011 08:33 AM
Braided fuel line.... muscarmad Engine 14 06-21-2010 10:00 PM
Hole in Braided A/C Line 30 sportcoupe Electrical 6 07-13-2008 12:39 PM
Braided line flaming79 Engine 6 03-15-2006 02:10 AM
