Teflon tape on brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2003, 08:21 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Post Teflon tape on brake lines
I'm putting a new master cylinder in my Jag. I was wondering if you can use Teflon tape on the flare fittings to help prevent leaks or do you need it?
Regards
Mark
Old 04-15-2003, 08:36 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
No it will cause more problems that it will solve. Chance of getting the tape into the system. Flares are designed for metal to metal seal only.
Old 04-16-2003, 05:12 AM
Post
NO NO NO NO
Dragon J's Avatar
Last journal entry: Harley/Fire
Post
Right on willys- if they don't seal there is something wrong with the flare- redo- don't try to fudge w/teflon... stopping is just as important as going!!!
Old 04-16-2003, 05:25 AM
dinger's Avatar
Post
ditto, ditto, ditto. not something to mess with, jag, we'd like to see you around for awhile.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
