Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tell me about this SBC
Old 04-03-2013, 11:41 AM
Slammedsi's Avatar
Slammedsi Slammedsi is offline
Originally Posted by 1971BB427 View Post
It really depends on how high you plan on winding the engine. I'd feel comfortable going to 6,000 rpm with factory rods if everything is built correctly. After that it gets a little shaky with stock rods.
Originally Posted by vinniekq2 View Post
to make 1.5 hp per cubic inch,I see decent solid roller cam,over 10:1 CR,single plane intake,850 CFM carb,heads that flow 300 ish cfm,1 3/4 primary long tube tuned headers,maybe even stepped headers,drive line parts to take the power,suspension to plant the power
Thanks for the help guys. I was planing on going single plane and keeping it under the 6500 rpm mark. If there is doubt that the rods would handle something like that then while I'm there i might as well do it right.
Maybe go with something like the Scat engine kit that has the full rotating assembly. Like this one, But this one has Hypereutectic pistons.
Scat Engine Rotating Assemblies 1-92300 - SummitRacing.com
