Tell me about spools and the GM 10 bolt. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 08:30 PM
Slammedsi's Avatar
looking to add a spool or mini spool to a GM 8.5 10 bolt. I wanted to know what y'all think should be used. Mini or a full spool? Being used for burnout contests and 1/8th mile runs some where in the upper 8's on drag radials.
Old 04-05-2013, 09:13 PM
vinniekq2's Avatar
racing only? kind of a pain on the street if you need to turn corners or parallel park
The Following User Says Thank You to vinniekq2 For This Useful Post:
Slammedsi (04-05-2013)
Old 04-05-2013, 09:15 PM
big gear head's Avatar
High Performance Rear Ends
If you are not going to use c clip eliinators then you will have to use a mini spool. If you are going to use c clkp eliminators then a spool is best.
If this will be used on the street at all then a spool of any kind is a bad idea. They are dangerous on the street.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (04-05-2013), Slammedsi (04-05-2013)
Old 04-05-2013, 09:59 PM
Slammedsi's Avatar
I understand that the are not safe for street use. There will be non
Just track use. I have read where peple have broken mini spools. Saying that they are not as strong as a full spool. I haven't used them so I was not sure.
Old 04-06-2013, 10:23 AM
S10xGN's Avatar
Gotta love a turbo!
Here's some "food for thought" on what happens to a c-clip axle when it breaks:
HTH,
Russ
Old 04-06-2013, 10:51 AM
Slammedsi's Avatar
Ya I know the entire shaft will come out if the c clips break.
Old 04-06-2013, 01:16 PM
Slammedsi's Avatar
Is there a way to find out if the axles are 28, 30, 33 without pulling the diff cover and digging in. Rearend is from a 92 suburban.
Old 04-06-2013, 02:27 PM
The last image is of a 1-ton axle after the hub locknut has come off taking the hub and the axle shaft.
Old 04-06-2013, 06:23 PM
'92 will be 30 spline.
Old 04-06-2013, 10:00 PM
Slammedsi's Avatar
Thanks big gear, Is it just based on years. Or is there a visual difference?
Old 04-06-2013, 10:45 PM
Most mini spools manufactures do not recommend mini spols to be used on pavement. If you wanting a locked axle just get a spool. I think it was summit that came out with some really inexpensive spools. Ford mini spools are slightly stronger than GM units. GM mini spools are slightly better "Lincoln lockers". Just my opinion.
Old 04-07-2013, 08:59 AM
GM upgraded the 8.5 to 30 spline in '90, so all 8.5 rear ends from '90 and up are 30 spline.
Old 04-07-2013, 09:38 AM
Slammedsi's Avatar
Thanks biggear
Old 04-08-2013, 09:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Slammed, I'm real glad to see that you're not looking to weld the spider gears or something along those lines!
A page w/some options for what type of rearend to use can be seen here.
Good luck.
Old 04-08-2013, 11:37 AM
Slammedsi's Avatar
Good luck.
Haha funny you ask that. I also have a 85 k20 with a simi float 14 bolt. I welded the rear spiders on it. BUT... it never sees street use and is used for mud bogs. It sets on a set of 40 inch boggers.
dana 60 spools ballsout1 Transmission - Rearend 1 01-24-2013 07:48 PM
spools diamond mike Transmission - Rearend 9 01-06-2010 09:38 AM
Street Spools ??? Augusto Transmission - Rearend 15 04-17-2007 09:51 PM
mini spools bigwildgrin Transmission - Rearend 11 10-23-2006 06:44 PM
spools camino_man Transmission - Rearend 3 02-08-2003 01:50 PM
