-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   tell me what you think of this interface pad idea (http://www.hotrodders.com/forum/tell-me-what-you-think-interface-pad-idea-228363.html)
tech69 01-13-2013 08:51 PM
In most shops you'll see your 6" DA paper for 40-220 grit in sticky back, but for 320-2000 you will see it in hook and loop. This creates a little issue with backing pads. So say if you want to foam pad something it will usually be with 320-2000, but there's also occasions where you want to foam pad something in 80 or something that's normally stocked in shops with sticky back. So what do you do? I just grab a piece of 2000 in hook n loop and just stick a piece of sticky back paper on top. It works ok I guess, but I want to make an adapter pad with hook n loop on one side and directly on the other side a leather pad to accept sticky back sanding paper. So it wouldn't be the foam interface pad, just an adapter of sorts so the interface pad would accept sticky back paper. Any thoughts on this?
carolinacustoms 01-13-2013 09:20 PM
Not sure how well it would hold up, but you could try gluing a piece of leather to a piece of 2000 hook n loop? Or maybe a coat of epoxy on a piece of H/L 2000. Probably crazy ideas but it is getting late :D
By the way you can get H/L 80/180 grit paper its all I use on my DA sander (not sure about 40 grit, I never use anything that coarse) . Maybe that's an option too?
Kelly
tech69 01-13-2013 09:23 PM
yeah but most shops use the sticky for that grit. I'll try it out. Just wondering how many others get annoyed about the two types of da paper with usually one in the paint area and one in the body area.
Overthinking...the mind just gets kooky at night on a Sunday. :D
carolinacustoms 01-13-2013 09:32 PM
Oh I agree it would be a nice invention if one could figure out a good way to do it. Maybe some kind of plastic with a velcro/ H&L backing would work?
tech69 01-13-2013 10:00 PM
I'm gonna take the hook n loop from an old piece of 2000 that I already use cause at the end of their usage as an interface adapter it will just be a thin layer of tan paper and the hook n loop itself. I'll glue on a piece of that plastic leather and post my results.
carolinacustoms 01-13-2013 10:08 PM
Sounds like a plan. I was just thinking I have an old foam interface pad laying somewhere that the H&L was separating from the foam. If I can find it I may just try something myself. I'm not trying to steal your idea mind you, I just had the thought of how it may be possible.
Kelly
carolinacustoms 01-13-2013 10:13 PM
I think I have found what we are trying to invent :rolleyes: After going to the link scroll down a little and they have one pictured
Tools for the Marine Industry - DYNABRADE Europe - (Version JPG) - Page n° 23 - PDF Catalogue | Technical Documentation | Brochure
Kelly
tech69 01-13-2013 10:35 PM
We'll go out on a fishing trip with him with a couple of buckets of concrete...We'll be rich I tell ya!
I was thinking about that whole concept of simple tools you can make. I instantly thought of wood and all the amazing things you can do it to it shape things and bend things, that annoying interface soft pad only coming with hook and loop, and other knick knacks.
carolinacustoms 01-13-2013 10:43 PM
I'm blaming insomnia and John L for frying my brain on the trivia thread. Good thing google doesn't charge by the question lol
