tell me what you think of this interface pad idea - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2013, 08:51 PM
put up or shut up
In most shops you'll see your 6" DA paper for 40-220 grit in sticky back, but for 320-2000 you will see it in hook and loop. This creates a little issue with backing pads. So say if you want to foam pad something it will usually be with 320-2000, but there's also occasions where you want to foam pad something in 80 or something that's normally stocked in shops with sticky back. So what do you do? I just grab a piece of 2000 in hook n loop and just stick a piece of sticky back paper on top. It works ok I guess, but I want to make an adapter pad with hook n loop on one side and directly on the other side a leather pad to accept sticky back sanding paper. So it wouldn't be the foam interface pad, just an adapter of sorts so the interface pad would accept sticky back paper. Any thoughts on this?
Old 01-13-2013, 09:20 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Not sure how well it would hold up, but you could try gluing a piece of leather to a piece of 2000 hook n loop? Or maybe a coat of epoxy on a piece of H/L 2000. Probably crazy ideas but it is getting late
By the way you can get H/L 80/180 grit paper its all I use on my DA sander (not sure about 40 grit, I never use anything that coarse) . Maybe that's an option too?
Kelly
Old 01-13-2013, 09:23 PM
put up or shut up
yeah but most shops use the sticky for that grit. I'll try it out. Just wondering how many others get annoyed about the two types of da paper with usually one in the paint area and one in the body area.
Overthinking...the mind just gets kooky at night on a Sunday.
Old 01-13-2013, 09:32 PM
Oh I agree it would be a nice invention if one could figure out a good way to do it. Maybe some kind of plastic with a velcro/ H&L backing would work?
Old 01-13-2013, 10:00 PM
put up or shut up
I'm gonna take the hook n loop from an old piece of 2000 that I already use cause at the end of their usage as an interface adapter it will just be a thin layer of tan paper and the hook n loop itself. I'll glue on a piece of that plastic leather and post my results.
Old 01-13-2013, 10:08 PM
Sounds like a plan. I was just thinking I have an old foam interface pad laying somewhere that the H&L was separating from the foam. If I can find it I may just try something myself. I'm not trying to steal your idea mind you, I just had the thought of how it may be possible.
Kelly
Old 01-13-2013, 10:13 PM
I think I have found what we are trying to invent After going to the link scroll down a little and they have one pictured
Tools for the Marine Industry - DYNABRADE Europe - (Version JPG) - Page n° 23 - PDF Catalogue | Technical Documentation | Brochure
Kelly
Old 01-13-2013, 10:35 PM
put up or shut up
We'll go out on a fishing trip with him with a couple of buckets of concrete...We'll be rich I tell ya!
I was thinking about that whole concept of simple tools you can make. I instantly thought of wood and all the amazing things you can do it to it shape things and bend things, that annoying interface soft pad only coming with hook and loop, and other knick knacks.
Old 01-13-2013, 10:43 PM
I'm blaming insomnia and John L for frying my brain on the trivia thread. Good thing google doesn't charge by the question lol
Soft interface pad for paint removal Mach1460 Body - Exterior 4 07-17-2012 04:55 AM
computer interface subdude79 Electrical 12 01-15-2006 05:50 PM
Wool Pad/Foam Pad/Products/whats ur Flavor BondoKing Body - Exterior 19 12-20-2005 12:30 AM
real virtual car: automotive gaming interface Jon Hotrodders' Lounge 4 05-14-2005 03:20 PM
1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea. 1969css Introduce Yourself 1 12-22-2004 05:18 AM
