Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tell me why
Thread: tell me why
Old 06-24-2004, 11:17 AM
JamesRS's Avatar
JamesRS JamesRS is offline
I think you should try changing the vacuum secondary springs on the carb. The silver spring that the 1850's come with is pretty stiff, and doesn't let all four barrels open as soon as most people want them to. Here is a link to the jegs site that sells the spring kits.
http://www.jegs.com/cgi-bin/ncommerc...37&prmenbr=361
For $10.00 it's worth trying out. Go to the lightest spring in the pack, and work your way back from there. Listen to the carb as the engine revs to make sure the secondaries are opening up at about 3000 - 3500 RPM's. That should give you the best all around performance.
