Tell me why? Chevy CLOYES STREET True Roller Timing Set sp 9-1100SP - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2010, 10:16 AM
not fit engines with an factory cam.
I have an marine cam and would like to stay with it.
what is the problem using Roller Timing Set sp 9-1100SP.
GEAR SET FOR 1955-1987 SMALL BLOCK CHEVY MOTORSEXCEPT THOSE ENGINES WITH A FACTORY ROLLER CAM.
BR Bob
Old 10-05-2010, 10:50 AM
Last journal entry: Paint
The factory roller cams use a cam plate. The back of the cam gear on the roller cam engines is made different to clear the bolts on the cam plate..
Old 10-05-2010, 10:56 AM
This is a factory roller cam gear.
Old 10-05-2010, 11:10 AM
If you can find just the roller cam gear for the roller chain, that is all you need to make it work.
Old 10-05-2010, 01:27 PM
ericnova72's Avatar
More for Less Racer
Back of the cam gear is machined different for 55-87 than it is for 88-up, because the roller cam has a cam thrust/retainer plate that bolts to the block behind the gear, and the roller cams front bearing journal has a step machined on it to fit this retainer. The bolt pattern is also different between 55-87 cams and 88-up roller cams, that gear won't even bolt to your cam.
What year block are you trying to fit this cam into??
Old 10-05-2010, 01:38 PM
Roller cam and non roller cam blocks.
ID:	48645   Click image for larger version
Old 10-06-2010, 08:18 AM
Hello my block is an 86.
Casting no 10054727.
Old 10-06-2010, 12:24 PM
Hello v8&4speed.
I have the right version so it means I have non roller cam blocks,
but my unit is without the three allen key bolts. What does this means?
Thank you all for your help.
BR mo
Old 10-09-2010, 12:45 PM
Rogers Performance's Avatar
Not all 86 blocks were roller cam some were flat tappet also the roller cam has a smaller front on it.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cloyes timing product failure Tim Feeley Introduce Yourself 1 11-10-2004 07:05 PM
Cloyes timing product failure Tim Feeley Engine 8 10-30-2004 08:07 AM
Chevy 327 Timing Problems EazyDuzIt102 Engine 5 09-03-2003 12:04 AM
HELP! New timing set too loose dran04u Engine 1 06-26-2003 04:14 PM
