Telling a type of Drive axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2005, 09:04 AM
Dreadlord's Avatar
Proficient Motorsports - Owner
Last journal entry: The Trucks Redemption
How do you tell what type of rear end you have in a ford truck. Like if its a dana and what kind of rearend it has.
Old 09-07-2005, 09:37 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Diff ID
Have a look here:
http://www.peytonperformance.com/rodney/powertrax.htm
or if you want to post some pics, or give tag# info, perhaps I or someone else can help you to identify it.
What "Ford truck" is it out of? (Year, Model, 2WD or 4X4)
Don
Old 09-07-2005, 05:02 PM
FourSpeed460's Avatar
Ford 460 The only way to go!
It is the same truck that is having the fuel/ignition problem. A 1983 Ford F-350 4X4 with a four speed 460, Single rear wheel. the reason we asked is I would like for it to be a posi instead of the limited slip thats in it. I am trying to find a spool/mini-spool for it but I am not sure what rear end is in it. I think it is a Dana 44 but i am not sure.
Old 09-07-2005, 08:46 PM
tornado-tech's Avatar
It should be either a Dana 70 or Dana 60. Here is a listing to help you tell them apart: http://mav.wastegate.net/tech/dana60-70.html
Old 09-07-2005, 10:05 PM
I am prety sure it looks alot like the Dana 60 But im not positive. I will have to look when I get a chance. you can tell the difference in rearends by the cover. Correct? Thanks bryant
Old 09-07-2005, 10:13 PM
The Dana 60 and Dana 70 use the same cover but the Dana 70 is a beefier axle. You might also look for the numbers "60" or "70" on the housing which most all Dana axles have. Since it is a f-350, I am willing to bet that you got the Dana 70.
Rack&Pinion on old type straight axle austin Suspension - Brakes - Steering 53 01-29-2007 09:18 AM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 05:20 PM
determining right dropped axle adtkart Suspension - Brakes - Steering 4 08-12-2003 06:48 PM
Spun Axle Bearing RAW Transmission - Rearend 0 06-26-2003 03:49 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 09:47 PM
