I can only tell you about late model G.M. The do have a temp sensor in the grill that is very similar to the intake air temperature sensor in the snorkel
between the throttle body and the air box. Some of them the compass calibration is controlled via class 2 communication circuit in the body control module. Look into the aftermarket ones, I've seen them advertised and they should be self contained and easier to install into something that didn't originally have one. good luck. |
Temp & Compass
Doc here,
If you want an OAT (outside Air Temp) gauge, you need an external sender... If you get a "Whiskey" (wet) compass, It is stand alone.. You can find both at an airport instrument shop..but their expensive..(anything with a TSO is..) And then you'd have to fabricate a mount for both too... Cheapie Instruments are available , as was said, aftermarket at the auto parts supermarket ... (next to the fragrance trees.. )Doc
Aftermarket Solutions Electronic & Electrical Innovations |
