Temp fan switch location - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2012, 10:01 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I have got a dual temperature (195/210) fan switch for you cutlass and I need to have a bung installed onto my radiator. Is it best to put this on the hot side cold side of the radiator? I would think if its on the hot side it will be cooling the water off more than it needs to where as if its on the cold side it would keep the water temp at a more constant temp due to the fact it only cools it down to the 195*F area. Or if it should be on the hotside can I put it in the thermostat housing. It will be controlling a two speed single 14" fan.
Thanks!
Old 08-01-2012, 11:25 AM
ogre's Avatar
the 'Duracell Project'
this was my fix to add a bung for the fan sensor on my stock 58 truck radiator
short piece of ss exhaust tubing and half of a ss 3/8 npt coupling in the lower radiator hose.
i also added a stud to ground the tubing as it is mounted in rubber on both sides
Old 08-01-2012, 11:26 AM
ogre's Avatar
Old 08-01-2012, 11:37 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Consideration is given to the engine temp 1st not the temp in the rad. If in the coldest area or rad outlet back to the motor you are not responding to the engine temp soon enough.
Inlet area of rad would be my choice, works for me anyhow.
Is that a LT1 orge? so on the bottom line you have it in the rad inlet or hot side correct?
Old 08-01-2012, 11:38 AM
Listen and Learn
Wiki Edits: 7
nice. Thats not a bad idea. I believe my end tanks are brass. They have a gold color where the paint has chipped off. Would I have to solder a bung onto it if I went that route. Also do I go off of the cold side temp?
Old 08-01-2012, 11:58 AM
Listen and Learn
Wiki Edits: 7
Alright thanks for the reply. I am having a friend who makes stuff with his lathe make me a bung because I could not find one online. I need a 14mm x 1.5 bung. How hard is brass to solder?
electric fan temp switch g.m. stich626 Electrical 6 01-28-2012 07:21 AM
Temp switch for electric fan solidaxel Electrical 2 03-05-2005 01:31 PM
Water temp sensor location for fan switch subman17 Engine 4 11-10-2004 01:47 PM
electric fan temp switch probe, problem 39chevy Electrical 3 08-07-2004 08:28 PM
electric fan (Adjustable temp switch) QUESTION 39chevy Electrical 0 06-16-2004 08:54 PM
