temp. gauge....mechanical or electric?
Hello,
trying to decide which is most dependable. Heard the electric gauges take longer to respond to temp changes...any factual basis for one over the other? Thanks, James |
I would take mechanical over the electric any day. But that's just me it seems they are just more reliable. JMO
Cole |
X2 on that, I like all mechanical, except dash board fuel pressure, that is a game changer.
Either one will work fine. The mechanical gauge requires a larger hole in the firewall to allow the sensing bulb to pass through. Kink or break that tube and the gauge is junk. Electric is a lot easier to route and will work fine. As for response time, either one will respond faster than your cast iron motor will change temperature, so that's meaningless in the real world.
thanks for the responses guys
Electrical gages are also a bit sensitive to voltage.
a bad or weak ground----or----an electrical system that is not up to par and running below 13volts will cause high temps readings---low oil pressure reading. I prefer the electrical----mine work just fine |
| Mechanical oil pressure gauge problem | v8hed | Engine | 19 | 08-02-2011 07:09 AM |
| Mechanical screw on temp gauge | fierosum | General Rodding Tech | 2 | 06-07-2009 07:47 AM |
| mechanical oil pressure gauge | hemigremmy | Electrical | 2 | 08-15-2007 10:07 AM |
| mechanical oil gauge bleeding? | cboy | Engine | 5 | 06-28-2005 04:37 PM |
| should i get electric or go with mechanical? | 7fastelc0 | Engine | 6 | 11-12-2002 12:01 PM |
