Temp Gauge Sending Unit and Aluminum Heads - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-04-2012, 11:59 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
Well damn. So much for the theory if one is good two must be real good.
Thanks
  #17 (permalink)
Old 03-05-2012, 12:06 AM
blwn31's Avatar
All you're trying to do is move warm water up to the thermostat so the as to not get the heads overly hot and large temp swings. I just keeps the entire motor at a more stable temp. You can try 2 holes, see if you like the results??? I personally didn't.
Keith
  #18 (permalink)
Old 03-07-2012, 02:38 PM
Originally Posted by blwn31
Since you replaced the sending unit I would tend to believe the temp gauge. The heads will run hotter than the intake, that's why I like to take the temp from the intake near the thermostat. One thing I have done to my engine, is drill a small hole (1/16th) in the thermostat to keep a good supply of hot water moving up to the thermostat. I've found this keeps the engine temps more stable instead of the big swings I used to see. Difference for me is, the engine being all aluminum, it was sucking so much heat out of the cylinders, I felt the engine was getting to hot before the thermostat would open. Once I put the bypass hole in, everything became normal.
Keith
My son had this same problem on a 383 stroker w/450 HP. It was his torque converter that wasn't high enough. He ended up with a 2600-2800 stahl on the converter and the overheating stopped. Barry
  #19 (permalink)
Old 03-07-2012, 03:54 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
u drill steam holes in those heads?
  #20 (permalink)
Old 03-07-2012, 10:51 PM
Steam holes are drilled and I have a 3200 stall converter.
I put the new sending unit in, but I have to find a connector for it now. They give the plastic housing for the connector but not the terminal?
  #21 (permalink)
Old 03-10-2012, 09:04 PM
Hot rodding is so much fun
That's what I have to keep telling myself.
New problem, the old school sending unit is the wrong resistance. The gauge goes all the way up.
Any ideas what might have a different resistance? I believe I was told there were only two, but I could be talking out my *****.
I thought about buying an adapter fitting and using my old gauge, but there is no way the sending unit would sit in the coolant enough to work properly.
  #22 (permalink)
Old 03-10-2012, 09:29 PM
Why don't you just install a brass pipe bushing in your manifold and use your original sending unit?
  #23 (permalink)
Old 03-10-2012, 09:46 PM
I thought about that, but I've had troubles with those in the past. I wasn't sure if it would allow it to stick in the coolant path enough either, but it's definitely worth a shot.
  #24 (permalink)
Old 03-11-2012, 09:30 AM
Just check with a good hardware store and your auto parts store as to who has the fitting that will work for you. They each will have a different supplier. Shouldn't be a problem.
  #25 (permalink)
Old 03-12-2012, 08:24 PM
I found one without the hex head on it so the sending unit would sit in the coolant as far as it could. So far so good.
Thanks for the help everyone
Tranny temp gauge sending unit location yragat Transmission - Rearend 12 12-28-2008 05:12 PM
Temp sending unit busterwivell Hotrodding Basics 5 09-16-2008 08:26 PM
Temp. gauge sending unit parameters? Thinking Man Electrical 0 11-20-2007 07:12 PM
Temp sending unit GMac Electrical 11 10-27-2004 01:46 PM
Temp Sending Unit? Seon Engine 2 06-23-2003 04:01 PM
