Temp Gauge Sending Unit and Aluminum Heads
I have a street 406 small block with aluminum AFR 195 heads and I am having some temp gauge problems. When the truck is idling, the temp gauge moves up into the 220-260 area. When I start driving again, the gauge goes back down. It's clear to me that the engine is not actually overheating and I have verified this with an infrared thermometer at the water neck. At first I thought it was a bad sending unit, so I replaced it. It was old anyway, so I didn't bother testing it. The problem was completely unchanged. I also used the thermometer on the sending unit case and it also shows an increase in temperature when this happens.
The heads do have the steam holes drilled, but I am starting to think that the gauge is just picking up hot spots when the coolant flow is minimal. Does this sound correct? Should I move the sending unit to the intake? Not worry about it? Any suggestions? Thanks |
I thought about the gauge being faulty also, but the resistance of the sending unit goes up with gauge movement. If the sending unit is telling the gauge to go higher, and it is, I think I can rule that out.
As for moving the sending unit, is there any problem with moving it to the back of the intake? I have an Edelbrock RPM Air Gap intake and there are ports at all four corners. I will try the thermostat hole though. I have heard of that before but I didn't think it would change this problem. Thanks |
Just a thought . If you have any question about how good the earth is between the sender unit and the chassis , rig a second earth from the brass casing on the sender unit with a clip to the chassis and watch for any variation on the gauge once again. I have al edelbrock heads and rpm intake on my 347. The temp sender is close to the thermostat, is new and works fine. A victor water pump is also used. I run two earth straps from the engine, one 8mm to the firewall from the rear of one head and a 10mm from next to the engine mount to the chassis rail. Also the gauge itself maybe having an earthing issue and could be proved out by using a second temp earth.
Good luck Al |
Just in case anyone is a little confused by 67Mustang AL, "earth" is Australian for ground.
He does make a good point. make sure there is a good ground between the engine, and the gauges. Do not just assume the engine is grounded to the chassis, and the gauge itself is also. |
You might want to raise the overall coolant temp and increase the pressure limit from the cap. With aluminum heads this will improve combustion efficiency by putting more heat into pushing the pistons instead of warming the atmosphere and the higher pressure will help prevent localized boiling around the exhaust seats. It's important to keep them wet, when steam forms the local spot cooling in this area is greatly reduced. Many guys doing serious racing with the SBC tap a coolant source off the pump horns and deliver it into the head under the header and right between the exhaust ports as a means to keep this area cooler. Others enlarge the coolant transfer holes in the head and/or gasket at this point to facilitate the same end of getting some extra coolant flow on these adjacent valve seats. In simple terms the faster heat transfer rate of aluminum will get your attention, as it has and yes your shot about the gauge just picking hot spots is right on. Bogie |
I have a separate, 4-gauge ground from the alternator to the frame, so the ground shouldn't be a problem.
OldBogie, by raising the temperature you mean running a hotter thermostat? I have a 195 in it now, but the cap is just a Stant replacement cap, so maybe it's 15-16lbs. |
Bogie |
Drilling a 1/8" hole in the thermostat allows the air to escape into the radiator when your filling you system. That way you eliminate trapped air. Usually when I'm tracking down a problem with a questionable temp reading I install a tee so I can add a known mechanical temp gauge. Both read the same, it ain't the gauge. Two diff temps, you have a gauge problem.
It's a new AC Delco radiator, but it does have the plastic tanks. I'll have to check the cap rating to be sure of what I have on there now.
Also, I belived I checked the coolant passages in the gaskets when I built it and they matched the holes in the block and head. I'm not sure if I've seen a 400 head gasket that didn't match, but I could be wrong. |
I have my temp sending unit on the rear of the Edelbrock RPM heads. I have alway felt that the temp spikes were because the alum soaks up the heat faster than iron. Also at the rear of the heads is supposed to be the hottest part of cooling system.
I also have a sender at the thermostat housing but it turns out it is wired differently so I have not used it. The thought that there is steam forming around the exhaust is interesting. I have a regular coolant loss problem that I have been chasing for 3 years. All the minor leaks have been fixed and I have a larger coolant recovery system. I think the higher pressure cap may really be the answer. Ceartainly worth a try as crusing season is knocking on the door. |
Not sure how electric senders are made, but if this is a mechanical gauge-make sure the bulb that sticks into the head is not contacting the actual aluminum casting inside the water jacket. That will make it read all kinds of funny. If so, get a longer guage fitting to keep that from happening...
Did some work today. I removed the thermostat, drilled two 1/8" holes, and reassembled. I also confirmed that it is a 195 thermostat and that the cap is 16lbs.
I also attempted to move the sending unit into the manifold. The sending unit I pulled out of the head is 3/8" pipe thread, but the holes in the manifold are 1/2". My Dad said to get a sending unit for a car from the 60's or 70's. Can anyone confirm this is correct or that the resistance is the same? |
You don't need two 1/8" holes. You will move a ton of water through a quarter inch combined hole. The thermostat probably won't ever open. Get another thermostat, drill one 1/16th to 1/8th inch hole. When I originally did mine I drilled two 1/8th inch holes 180 degrees apart. I have since downsized to one 3/32nd inch hole. My temps are nice and stable now with no spikes.
Keith |
| Tranny temp gauge sending unit location | yragat | Transmission - Rearend | 12 | 12-28-2008 04:12 PM |
| Temp sending unit | busterwivell | Hotrodding Basics | 5 | 09-16-2008 07:26 PM |
| Temp. gauge sending unit parameters? | Thinking Man | Electrical | 0 | 11-20-2007 06:12 PM |
| Temp sending unit | GMac | Electrical | 11 | 10-27-2004 12:46 PM |
| Temp Sending Unit? | Seon | Engine | 2 | 06-23-2003 03:01 PM |
