temp guage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2007, 07:48 AM
temp guage
i have aVDO water temp guage always reads about 15-20 degrees higher heat than engine is, no teflon tape on sender good ground, any suggestions, ground not connected to battery but has a good ground, any help will be appreciated, thanks jO
Old 10-04-2007, 08:29 AM
302 Z28's Avatar
Automotive electric temp gages are not that accurate IMO. You could try another sender, but I would not hold out much hope for it making any difference. If you are comfortable that the engine is not actually running as hot as the gage indicates I would just leave it alone, if not then install a mechanical gage as they are more accurate.
Expensive industrial temp measurement usually has a 2 degree margin of error. I would suspect that auto temp measurement is a bit less accurate.
Vince
Old 10-04-2007, 08:52 AM
Frisco's Avatar
Glad To Be Here
If sender is installed in the cylinder head this is normal because of the close proximity to the exhaust.
If sender is installed in the intake manifold and is reading high; sender is off and you should consider replacing it.
Sender should match the gauge also.
Old 10-04-2007, 09:46 AM
temp guage
thanks
have replaced guage with new sender and all new wiring. probably just bad guage, i do have another sender will replace,not much involved. thanks for the imput.
Old 10-04-2007, 10:59 AM
302 Z28's Avatar
Forgot to ask, how are you confirming the actual temp of the engine versus your electric gage?
Vince
Old 10-05-2007, 02:28 AM
electric gauges imo
i never trusted electric gauges, granted in my 50 plus years of hot rodding they have improved , i still prefer mech gauges. but even mech gauges are not equal , you get what you pay for !
Old 10-05-2007, 11:04 AM
Wiki Edits: 49
I have the exact same problem with the electric temp gauge thats in my '53. It constantly reads about 15-20 degrees higher than the actual temp (verified by using a mechanical temp gauge). I called the manufacturer and they even sent me a new sending unit but it still reads the same. Lesson learned: inexpensive gauges aren't worth it. I guess you get what you pay for. I'm in the process of replacing these "cheapos" with a good set of Auto Meter gauges, with a mechanical water temp gauge.
Tranny Temp Guage = Oil Temp Guage? topdogger Transmission - Rearend 2 06-21-2007 09:59 PM
Need old temp guage 78 monte Engine 1 06-08-2006 11:13 AM
Temp guage sending unit 46_stvblt Engine 0 06-03-2004 09:41 PM
temp guage: up and down, and up and down! bullheimer Engine 5 03-18-2003 08:33 AM
temp guage want work 70 nova Electrical 1 02-23-2003 11:51 PM
