Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - temp guage help
Thread: temp guage help
Old 05-02-2013, 11:00 PM
sedanbob's Avatar
sedanbob sedanbob is offline
I missed that you mentioned adding the wire. It seems to me that the wire you added should function just fine to ground the base of the sensor. Generally, if a sensor already has thread sealant on it, it should be of a type that will not interfere with grounding the sensor. Liquid Teflon thread sealant (not the tape) should work. The tape can interfere with the sensor grounding.
