Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - temp guage help
Thread: temp guage help
Old 05-03-2013, 12:24 PM
bygddy bygddy is offline
Proud LOSER
Originally Posted by sedanbob View Post
I missed that you mentioned adding the wire. It seems to me that the wire you added should function just fine to ground the base of the sensor. Generally, if a sensor already has thread sealant on it, it should be of a type that will not interfere with grounding the sensor. Liquid Teflon thread sealant (not the tape) should work. The tape can interfere with the sensor grounding.
So any suggestions where to look next?
