temp guage: up and down, and up and down! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2003, 02:18 PM
bullheimer's Avatar
NEVER use credit cards!
Post temp guage: up and down, and up and down!
i just replaced my thermostat for the second time in a month (2.5 liter grand am)and the temp guage still goes up and down. stays at 100 degrees for the first 10 miles, then it goes up to boiling, the red light comes on, i turn on the heater and it goes down to 200 or so then down to 190, then up to 240 then down to 200. does this sound like a electric fan switch? or like i have a dead rat inside my cooling system floating around? i plan on draining it by removing the lower hose tonight after work. good idea?
[ March 17, 2003: Message edited by: bullheimer ]</p>
Old 03-17-2003, 04:08 PM
PrimeMover's Avatar
Sittin' on top of the world...
Post
sounds like a bad fan temp sender and, or restricted air flow. Lots of the newer cars have all kinds of junk stacked in front of the radiator like real thin finned AC condenser coils.. I've seen them plug up solid with road junk. I'd try pressure washing the core out towards the front of the car.
Old 03-17-2003, 04:14 PM
Post
check for a bleeder valve some were near the thermo. housing, could be an air lock. good luck JF
Old 03-17-2003, 04:53 PM
Post
dont wanna say you dont know how to work on cars or anything but make sure the thermostat is in right side up. sadly enough, it was me or my dad that accidentally stuck mine in upside down and it would have pretty weird temp. readings while driving it. just gotta look at the obvious sometimes :p
Old 03-17-2003, 06:03 PM
milner's Avatar
Post
i agree with toymobile, sometimes these things are a bear to get the air locks out of . leave the rad cap off and the heater on the hot position with the fan off. bring up to tempature. run at fast idle, but be very carefull, if it has a air lock, it will boil over and throw hot antifreeze. your cooling fan only comes into affect when idling. good luck!
Old 03-18-2003, 08:33 AM
bullheimer's Avatar
Post
i pulled off the top hose and let the water spray out all over a couple times, now it works okay, except my bud mr goodwrench has one of laser thermometers and determined my coolant temp. switch turning the fan on at 220 and off at 200 and says to replace it which i will do today. it's supposed to turn on the fan at 205 or so and off at 175. it ran okay otherwise on the way to work today so i must have dropped some piece of gasket or silicone down the hole or else that damn rat got in there when i wasnt lookin first time i changed the thermostat. i had them in the right way btw. $22 bucks for that sending unit. not bad
