Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Temp. Spray Booth didn't work very well
Old 10-06-2004, 10:59 AM
mytwopals's Avatar
mytwopals mytwopals is offline
Foam Panels
If you use the blue foam panels to build a spray booth, you will need to line them with plastic sheeting. The paint chemicals will eat the foam, otherwise. You will also need to use latex construction adhesive to glue the panels together. Normal construction adhesive will eat away the foam, too.
