Temp switch for electric fan - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2005, 03:21 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I am trying to find a temp switch that I can mount in the cylinder head of a SBC between cylinders 1 and 3 I think it is a 3/8 NPT, that will go to ground when the temp reaches 195* to 205* +/- I want this to provide a ground to the relay which in turn will om my cooling fan on the rad. I know there are companys that sell a kit, but all I want is the switch.
Old 03-04-2005, 03:31 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Go to your auto parts store and ask to look in their catalog for that switch. Not an Auto Zone 'cause they can only work off a computer screen with your car model. You should have a good, local, greasy rag parts store anyway if you do serious rodding. I get mine there and set them up exactly as you describe. I think the proper switch is a Chrysler number, even comes with spade electrical connection. As I reacall mine has two NO contacts that close @ temp but that is easy to incorporate in a grounding circuit.
Old 03-05-2005, 12:31 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I did the same thing to my nova last month yes its 3/8 npt. I got my switch at advance auto parts its a one wire and closes to ground @ 210 deg to ground my relay.
Electric Fan Temp. Sensors horvath Electrical 26 04-26-2011 03:04 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
Water temp sensor location for fan switch subman17 Engine 4 11-10-2004 12:47 PM
electric fan temp switch probe, problem 39chevy Electrical 3 08-07-2004 07:28 PM
electric fan (Adjustable temp switch) QUESTION 39chevy Electrical 0 06-16-2004 07:54 PM
