Temperature Gauge with Vortec Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2012, 11:13 PM
MI2600's Avatar
Member# 3287
I'm installing a 406 in my '72 El Camino, using Vortec heads and an Edelbrock manifold. Things were fairly standard until I got to the temperature gauge install. None of the "ports" on the intake are deep enough for a capillary gauge sensor. Also, the plugs in the heads are smaller than the sensor.
Anyone else resolve this problem?
Old 09-08-2012, 07:51 PM
you should b able to pick up a adapter kit at any auto part,s store that will alow for bigger fittings so you can use the larger diameter sensor,,
oil temperature gauge timemachine Engine 1 09-04-2007 08:46 PM
Temperature gauge jpelli Engine 9 11-21-2006 06:15 PM
Oil temperature gauge PAS55 Engine 4 05-24-2005 10:44 PM
Temperature Gauge Problem draft Electrical 4 08-30-2004 10:34 PM
temperature gauge buds53 Hotrodders' Lounge 2 05-08-2002 09:40 PM
