doesn't make much of a difference. but it does matter what side it goes in. it needs to be in the "inlet" side of the radiator. i have mine at the bottom right next to the tank, works fine. if you want to get nit picky, put it as close as possible to the hose .
i am assuming its a external probe ? the kind that pushes into the fins. |
Thanx Vortec
the old one that quit pushed into the fins. this new one has a cable tie set up that holds the probe aganist the fins. the unit is adjustable from 32/248 degrees F. i figure to set it @ about 170 degrees, the same as my thermostat
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| transmission fluid temperature | nixwillys | Transmission - Rearend | 1 | 04-16-2006 01:03 PM |
| Oil Temperature and oil types (long) | TurboS10 | Engine | 36 | 03-01-2005 01:51 PM |
| Big Temperature Gauge Problem | my350camaro84 | Electrical | 2 | 12-05-2004 07:20 PM |
| 77 chevy engine temperature sensor location??? | 77chevy400 | Engine | 4 | 07-09-2003 01:51 AM |
