Tempting new air fuel ratio afr analog gauge - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-30-2011, 03:13 PM
Silverback's Avatar
Boost Retard
If you're talking about the newer, cheaper WBO2s (I don't believe they have as big a range as a traditional WBO2s) you're usually talking about 2006 and up honda stuff, though I have heard that there were some used by toyota early 2000s, maybe 99, but have never had my hands on one for sure.
A lot of stuff that I've heard a lot of people call a 4 wire WBO2 is really a 4 wire NBO2 (NBO2 with a separate heater circuit)
  #17 (permalink)
Old 01-30-2011, 07:08 PM
001mustang's Avatar
About to get cold feet.
I would love wideband but guess I should buy pizza instead.
Was getting 18 mpg but determined carb was to lean.
Rejetted w/ basic plug readings and now getting 16mpg.
Car running perfect...based on seat meter.
Still interested in Junkyard special wideband. I don't mind collecting data on multimeter. Not like I will need to get readings every day.
  #18 (permalink)
Old 02-02-2011, 12:09 PM
sbchevfreak's Avatar
Licenced Automotive Technician
02 sensors generate voltage when exposed to oxygen, from approx 0-1 volt, with stoich being around 0.45 volts. Closer to 1 volt, lean, lower than .45 volts, rich. A 1 wire sensor has to be heated to 660*F to read, before that it is inaccurate. If you go with a 1 wire, mount it as close to the manifold/header as possible, or it will cool too much at idle and fail to read. This was a problem back in the early days of electronic fuel injection, as the vehicles would fall back into open loop when idling for extended periods. That, coupled with environmental law changes, lead to the adoption of heated sensors to speed entry into closed loop operation. It can be thought of as choke on or off.
  #19 (permalink)
Old 02-04-2011, 10:00 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Production cars have no need for a wideband O2 sensor, You will not find one, Car makers know the fairly narrow range their engines are gonna need to adjust for, That is why they overpay all those engineers the big bucks .
  #20 (permalink)
Old 02-04-2011, 11:09 AM
T-Bucket, Corvette, Mustang
I just purchased a new Innovate LM-1 for $225 on Amazon. Delivered yesterday and haven't opened it yet but will do so tonight and view hte DVD that is supposed to come with it. Will post later on my experience with it.
  #21 (permalink)
Old 02-04-2011, 01:43 PM
I'm with 001mustang I don't mind reading a multi meter if some one could jump in here and tell me how to do it. I don't even mine using a two or three wire 02 sensor.
  #22 (permalink)
Old 02-04-2011, 03:01 PM
001mustang's Avatar
I might just grab a few O2 sensors next time i visit local scrap heap.
weld bung in exhaust near headers.
google for voltage vs O2 specs.
if no specs:
voltage reading w/ car off (post hot lean idle)= 14.7 O2 (maybe)
volt w/ idle tuned lean= lean O2
volt w/ idle tuned rich= rich O2
test drive car and see what i get.
if lazy could just buy an elcheapo narrow band; save lotta time.
if your nice...maybe santa will put a wideband under tree.
  #23 (permalink)
Old 02-06-2011, 02:53 AM
SSedan64's Avatar
DIY Air Fuel Meter>> http://www.google.com/search?hl=en&s...q=DIY+air+fuel
Homemade Air Fuel Meter>> http://www.google.com/search?hl=en&q...qi=g1&aql=&oq=
I got lucky & ran across this on another Forum for $80 shipped:
http://www.autometer.com/cat_gaugede...id=3604&sid=11
http://www.autometer.com/productPDF/1143A.pdf
  #24 (permalink)
Old 02-06-2011, 03:15 AM
001mustang's Avatar
for $80?
must be missing wideband O2 sensor.
  #25 (permalink)
Old 02-06-2011, 03:57 AM
SSedan64's Avatar
for $80?
No, it's there, 5-Wire sensor. Just one of the knurled Gauge mounting nuts was missing. You can see all the parts in the Pdf. instruction link.
I just looked it up on Summit > http://www.summitracing.com/parts/ATM-4378/ I didn't know it was that much $$.
Analog guages joeford Electrical 0 10-12-2009 04:53 PM
holley projection 2 analog dpaps12 Hotrodding Basics 0 07-27-2009 07:05 PM
Digital vs analog ignition box Augusto Electrical 3 11-27-2008 09:18 AM
Fuel gauge help dpjim2 Electrical 7 05-27-2006 03:16 PM
Analog to digital gauge cluster akattp Interior 8 11-05-2004 03:42 PM
