Ten-Bolt Rebuild - Without Crush Sleeve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 11:50 AM
Is there a way to rebuild the ten-bolt diff without using a crush sleeve? In other words - use the appropriate shim stack instead.
Old 01-23-2007, 12:46 PM
I don't see why not. All that's needed is a tube spacer the right length to result in proper pinion bearing pre-load. Just be prepared to do some assembly / dissassembly until you get it right. Just curious, why wouldn't you use a crush sleeve?
Bob
Old 01-23-2007, 05:35 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Definitely, several differential sources supply solid sleeves and shims to replace crush sleeves.
Crush sleeves are not reuseable.
Solid sleeves are a popular addition for Ford 8 and 9" rear ends. Never build one without a solid sleeve. period. Currie has the Ford kit for about $ 10.
Solid sleeves are a much better way to do it because severe power loading cannot squish the sleeve and cause pinion slop and eventual gear wear or breakage.
Bolt Strength Question jamnut Engine 16 03-30-2005 07:11 AM
ten bolt 7.5 inch big455 Transmission - Rearend 8 01-17-2004 11:24 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
2 bolt and 4 bolt mains 70 nova Engine 4 03-22-2003 09:22 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
