“tension limiter” on e-brake cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2013, 12:57 AM
Got a ‘91 Ford E-350 truck. The foot-pedal emergency brake has a cable going to the rear axle where the adjusting screw pulls on the “equalizer bar” which pulls on the cables going to each drum. Ahead of the adjusting screw is what the shop manual calls a “tension limiter”, which I wrecked without knowing what it was. It is a U-shaped “cinch strap hook” with a bar that slides permanently down into the hook, if given enough force. You are supposed to put the e-brake pedal to the floor and rely on the limiter to set the proper tension. The manual says that when it slips there should be at least 350 lbs tension in the cables to each drum brake.
Broncos and F-150's have these too. Question is, do other years and models have the same 700 lb slip rating as the ‘91? People that don’t work on Ford brakes have never heard of these things.
700r4 TV Cable Tension ? jmichaelre Transmission - Rearend 5 08-03-2011 10:22 PM
brake pedal "tension"? raj4851 Suspension - Brakes - Steering 2 04-14-2011 09:29 PM
e-brake cable 41 kustom Transmission - Rearend 2 01-26-2007 09:59 PM
700R4 - TV cable tension problem wont allow WOT AussieModder Transmission - Rearend 4 07-02-2006 02:47 AM
TH350 TV cable tension????? Steve-0321 Transmission - Rearend 2 09-10-2004 05:11 AM
