Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - terminology question
Old 09-17-2004, 03:38 PM
BarryK's Avatar
BarryK BarryK is offline
The first coat is one coat and the 10 minutes is the flash time for the second coat. Each coat needs a flash time.
For what you are doing, if you want to put 4 coats on, no problem
For painting practice try spraying the epoxy like you would a clear coat-slick and wet.
