Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - terminology question
Old 09-17-2004, 02:48 PM
Dubz Dubz is offline
Muscle car fan
Originally posted by BarryK
The first coat is one coat and the 10 minutes is the flash time for the second coat. Each coat needs a flash time.
For what you are doing, if you want to put 4 coats on, no problem
For painting practice try spraying the epoxy like you would a clear coat-slick and wet.
yea, that's what i'm doing now, spraying just enough so it doesn't run, and then the last coat i do like i did the rest so it's got kinda the same look, it's either that or re-spray the peices allready done, which is about half the car.
'74 Gran Torino Project
351W, c6 trans, 9"
