terminology question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2004, 01:54 PM
Muscle car fan
I'm applying epoxy to my car for the flat black look to drive around in. And i've been told to put 2 coats of it on. The epoxy sheet says to spray one coat then another 10-15 min later. This I assumed was one application, and have been applying another applicatoin in an hour to an hour and a half when it is set up enough to topcoat.
I'm thinking this is 2 coats, but wondering if it's actually 4. The first few panels i sprayed fairly light coats, so i'm not terribly worried about them being too thick. Just wondering for the rest of the car, as now i know i'm supposed to be going slower, and have my gun set up better so it's laying it on thicker now.
would it hurt if i put more on? just wondering if i should continue with what i'm doing so the car will look all the same
'74 Gran Torino Project
351W, c6 trans, 9"
Old 09-17-2004, 02:38 PM
BarryK's Avatar
The first coat is one coat and the 10 minutes is the flash time for the second coat. Each coat needs a flash time.
For what you are doing, if you want to put 4 coats on, no problem
For painting practice try spraying the epoxy like you would a clear coat-slick and wet.
Old 09-17-2004, 02:48 PM
Muscle car fan
yea, that's what i'm doing now, spraying just enough so it doesn't run, and then the last coat i do like i did the rest so it's got kinda the same look, it's either that or re-spray the peices allready done, which is about half the car.
351W, c6 trans, 9"
Old 09-17-2004, 02:51 PM
BarryK's Avatar
Great, send picture when done and ok to put extra coat on other half, if that was your thought!
Old 09-20-2004, 01:29 PM
BarryK's Avatar
How did it turn out?
Barry
