test kit for ethanol ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2008, 08:12 AM
Has anyone heard of a test kit for checking for ethanol in gasoline????
Old 08-30-2008, 11:54 AM
Would specific gravity work?
sam-missle
Old 08-30-2008, 12:26 PM
techinspector1's Avatar
Wiki Edits: 326
http://theoutboardwizard.bizhosting...._test_kit.html
Old 08-30-2008, 12:58 PM
Greg T's Avatar
www.krusinklassics.net
Certainly no need for a kit. You can easily smell it. There's no mistaking that ethanol odor.
Old 08-30-2008, 02:36 PM
ethanol testing
I was told that Honda dealers used a glass bottle with a measured amount of water. Mark the water level, add gas and shake. Recheck the water level, ethanol will combine with the water.
Old 08-31-2008, 10:24 AM
JimFulco posted this in another thread.
http://www.fuel-testers.com/
thanks Jim
Old 08-31-2008, 02:00 PM
Plum Nasty's Avatar
Here To Learn From The Best!
I haul fuel for a living and we use a product that is made to check for water. When you put it on the stick it's brown. When you put it in a tank with water it turns red and if there is ethanol, it will turn yellow. You can talk to any fuel hauler and maybe get a tube from them or there yard.
Old 08-31-2008, 08:21 PM
Grab a plastic baby bottle. Put 5oz of water in it, and then add 5oz of water.
Shake well, and then let it set till the gas and water settle into 2 distinct layers.
If you now have 5.5oz of water and 4.5oz of gasoline the gasoline had 10% ethanol in it.
4L60E Shift kit. GMCTRUCKS Transmission - Rearend 8 05-20-2012 03:22 PM
Kit Car Nightfire Hotrodding Basics 34 07-20-2007 01:08 PM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 12:10 PM
where to get a quality 383 stroker kit ? (Long) Mustangsaly Engine 1 07-18-2006 06:13 PM
Lift Kit CustomFord Suspension - Brakes - Steering 1 05-09-2006 03:21 PM
