Google air checking. You could assemble the drums on a bench to the front pump and air check it fairly well. Will show you if you have a bad lip or square seal among other things. There's alot of stuff to check. The TH350 handbook has lots of info on this too.
I also pref to pressure check after you've installed the trans. Good luck! Greg |
Oh you didn't say if you rebuilt it or if it's used...
On that note pull the trans pan and look for goo/parts. If you find more than half cup of goo or any parts your trans needs a overhaul. Could pull the valve body and split it appart (look for a write up, piece of cake) and check for stuck valves, dirt and a bad seperator gasket. Also look at the color, you can see if it leaks (between halfs) it will normally cause it will look all dirty in a area and clean everywhere else. Also run a straight edge on the vb halfs. My C6 had a little spot on the gasket that blew out PLUS the pressure relief spring was broken. I think what happend is the relief spring broke then caused high pressure and broke the gasket. The trans I've saw either had bad lip seals in the pistons from age and cracking or junk in the VB. I also popped my C6 Servo cover off and a whole glob of goo came out... Also a sign Greg |
http://www.hotrodders.com/forum/th35...ch-145361.html
The picture with the drums assembled on the front pump is one way/part of air checking. http://www.hotrodders.com/forum/th35...ch-145361.html You put air into the feed hole to the piston that puts the clutches in and listen for a good thud (clamping the clutches), also should hold air pressure well. Another part is the I drum that's made into the case (low/reverse?), there is a feed hole in the case going to the drum. You put air there and again listen for a thud. Time spent in air checking is great cause then you know your seals are good. If your seals are good and your clutch clearance and endplay is in check you're golden (normally). Greg |
i already rebuilt the trans its all together on my bench right now so air checking any thing inside isnt going to happen now.
im pretty sure i put it back together right the only thing i might have messed up on is the valve body i might have a part wrong in their but i hope not. What could happen if their is lent inside the trans and what would happen if i have a part in the valve body in the wrong way. |
I personally would just pull the drums out and air check it... Would you rather know now or later that there's a problem? Hardest part about the overhaul IMO was putting the trans in the vehicle, not the rebuild. Heck the drums and everything wanna just pop right out when you pull the pump... Air checking wouldn't be a problem, it's your time and dime though.
Difference between a builder and a assembler is the builder knows that the first time you put something together prob wont be the last. Always mock assemble and if needed take it appart. The assembler tends to bolt things together without double checking. When I did my overhaul i used a manual. It had the airchecking stuff and lint warning right in the manual... A trans overhaul isn't something to jimmy rig, also is something you should learn about BEFORE you rebuild it... Ever seen one of these explode? Ever wonder why it costs so much to overhaul a trans? It is important to do this right. Good luck! Last edited by ekacpuc; 03-28-2012 at 03:51 PM. |
i did use a manual for the trans i didnt just throw everything together it took a month i went very slow if i got stuck i read the manual and even double checked on the internet. I just dont want this to blow up and hurt my car i know their isnt any lent in the valve but their might be some in the clutchs.
If their is lent how long will it take to tell that its cousing problems. |
It would just be one of those things that'd just happen... Not really a way to guess.
What makes you worry about lint in your clutches? Did you wipe em with a rag or something? I figure as long as you weren't in there with a paper towel or a rag than you're prob fine... I'd be worried if you used a rag in the valve body, maybe not so much the clutches. They slip for a sec when they engage so MAYBE if there was lint it'd burn it off? I don't gamble if I can help it though. I'm not a transmission guy though... I love learning about them but have only built one C6. Getting ready to do the TH350 next, they look ALOT alike inside. Greg Last edited by ekacpuc; 03-28-2012 at 09:43 PM. |
i cleaned alot of the hard parts and that stuff and wipped it off with shop rags so their might be some in the i didnt use the rags on the valve becouse after i looked in my bucket of cleaner i was seeing some rag lent.
The way I think of trannys is like a operating room.. If it was me I'd tear it down and clean it, this time with a lint free towel.
It's your road to plow though. Good luck, Greg btw I dunno what that other guy was talkin about.. |
That Line was copied & pasted from a Post above about the "Dyno", probably a Spammer doing the usual crap to get their Post count up so it doesn't look as slimey when they slip some Spam in.
| TH 350 Trans. Rebuild | JAMES MEDLEY | Transmission - Rearend | 2 | 07-28-2007 10:02 PM |
| Rebuild a Trans Yourself | budthespud | Transmission - Rearend | 12 | 04-06-2007 06:29 PM |
| Trans. Air Test? | grumpy1 | Transmission - Rearend | 1 | 03-25-2007 06:03 AM |
| 350 compression test results rebuild or leave it alone? | Buffed | Engine | 3 | 01-05-2004 03:55 PM |
| 350 trans rebuild? | jwart | Transmission - Rearend | 0 | 09-21-2003 08:06 PM |
