Test stand, how to guage horse power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2012, 06:25 PM
What is the best way to see how much Horse Power my engine can produce on an test stand? My stand is just home made so I am looking for something to adapt to it. Any suggestions would be great, thanks, Dana
Old 08-21-2012, 06:29 PM
vinniekq2's Avatar
make a list of parts and do calculations. take to an engine dyno and test.
Old 08-21-2012, 09:52 PM
327NUT's Avatar
In other words you can't, the only way is to take the engine to a dyno shop, pay your $500 or so and make some pulls. That way you will get the engine all dialed in and REALLY know what kind of hp it puts out.
Old 08-22-2012, 05:01 AM
Anything is possible. However, most likely not cost effective to make your own dyno.
I'm sure it has been done with varying results. Search the web.
One idea is air flow. An engine is just an air pump. The more air it moves the more hp it makes. So maybe just measuring how much air the engine can ingest would indicate hp (minus pumping losses of course).
good luck with that!
Old 08-22-2012, 09:07 AM
vinniekq2's Avatar
or bolt on a generator/water pump/propeller,all with known resistances
Engine Breaking Stand Running Engine Test Stand sloughbum01 Garage - Tools 5 01-06-2012 10:55 AM
Test Stand Instructions! 39chevy General Rodding Tech 7 10-01-2010 06:41 PM
Engine Test Stand freedom53 Garage - Tools 7 02-24-2009 07:07 PM
engine test stand mydixie Introduce Yourself 1 11-27-2004 07:02 PM
engine test stand chevynut General Rodding Tech 1 05-31-2003 02:50 PM
