Testing 3-4 clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 05:07 AM
blacklabzeke's Avatar
Testing 3-4 clutch
When checking the 3-4 clutch function on a 4L60 with air pressure, should it be able to hold until pressure or will it bleed off slowly? I am using an air nozzle with a rubber tip sealing the 3-4 hole on the input shaft. When I apply air pressure the piston pushes out and holds. When I stop the air flow but keep the hole sealed the pressure VERY slowly bleeds out. Is this normal or should I start looking for something wrong?
Old 03-31-2007, 07:36 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
normal.
Old 03-31-2007, 08:28 AM
Thanks Crosley!
Busted Clutch chrisflock Transmission - Rearend 1 04-15-2006 03:08 PM
Taurus SHO clutch issue... I know, big surprise... ViperMonster800 Transmission - Rearend 3 04-04-2006 08:33 AM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 03:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 09:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
