-   -   Testing GM HEI coil in cap (http://www.hotrodders.com/forum/testing-gm-hei-coil-cap-136071.html)
75gmck25 03-30-2008 02:03 PM
I'm replacing the distributor cap and wires on my '75 GMC truck, which is a 350 with a stock large diameter GM HEI distributor. I decided to test the old coil after moving it over to the new cap.
1st test- primary resistance, tach to bat terminals is near zero - pass
2nd test - secondary resistance, rotor button to ground - 15k - pass
3rd test - secondary resistance, rotor button to bat terminal - infinite - fail
Every reference I can find says to replace the coil if both of the secondary tests fail. There is no explanation on what it means if only one of the tests fails. Is this coil really bad?
I also tested an old HEI coil I had, and found it also failed the 3rd test, so I'm wondering if I am misinterpreting the readings.
Any input or suggestions?
Thanks,
Bruce
bracketeer 04-03-2008 08:49 AM
I have had opposite results. I was going across an intersection and the car just died. Did all the tests and it said, coil was good. replaced module. no luck. ended up being the coil in the end. best way to check is to try a coil you know is good.
LATECH 04-10-2011 12:55 PM
Hey Opyders
This is an old thread but the info is still good. It may help you out.
