Testing GM HEI coil in cap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2008, 02:03 PM
I'm replacing the distributor cap and wires on my '75 GMC truck, which is a 350 with a stock large diameter GM HEI distributor. I decided to test the old coil after moving it over to the new cap.
1st test- primary resistance, tach to bat terminals is near zero - pass
2nd test - secondary resistance, rotor button to ground - 15k - pass
3rd test - secondary resistance, rotor button to bat terminal - infinite - fail
Every reference I can find says to replace the coil if both of the secondary tests fail. There is no explanation on what it means if only one of the tests fails. Is this coil really bad?
I also tested an old HEI coil I had, and found it also failed the 3rd test, so I'm wondering if I am misinterpreting the readings.
Any input or suggestions?
Thanks,
Bruce
Old 04-03-2008, 08:49 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I have had opposite results. I was going across an intersection and the car just died. Did all the tests and it said, coil was good. replaced module. no luck. ended up being the coil in the end. best way to check is to try a coil you know is good.
Old 04-10-2011, 12:55 PM
LATECH's Avatar
Hey Opyders
This is an old thread but the info is still good. It may help you out.
loose HEI pickup coil mhamilton Engine 2 11-01-2006 03:50 PM
is there a way to test capacitor in gm HEI? COCHEV Engine 11 03-23-2003 06:42 AM
early optispark vacuum source 48Man Engine 7 01-16-2003 01:17 PM
GM HEI Dist. curve kit?? john69 Engine 4 09-24-2002 07:48 AM
GM HEI crshrmn3 Engine 2 09-07-2002 12:13 PM
