testing GM internal regulated Alternators - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2011, 02:49 PM
I have replaced the diodes, rectifier bridge, brush holders, and regulator. The windings test out OK. I have looked at neumerous wiring diagrams to check the wiring, and it still does not charge????? I am building a 62 chev short box pick-up. Any ideas or direction will help thanks
Ed Z
Old 06-23-2011, 03:09 PM
Ed Z
Do you have wire #1 from the plug connected to the idiot light on the dash? Have you converted it to a one-wire regulator?
Old 06-23-2011, 04:12 PM
T-bucket23's Avatar
Wiki Edits: 26
You can quickly test the alternator a couple different ways. Temporarily feed battery voltage to all three terminals, (the large stud and both small terminals), It should charge, if not and it is in fact grounded, then the alternator is defective. You can also test the regulator on the car, there is a small d shaped hole on the back of the alternator that has a tab from the regulator in it. If you short that tab to ground (alternator case)it will effectively full field the alternator. If it works with the tab shorted the regulator is no good.
Chet
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
How to Check & Rebuild G M Internal Regulated Alternator Rob Keller Electrical 11 06-08-2007 10:44 PM
G M Internal Regulated Alternator Rob Keller Electrical 62 04-22-2007 02:05 PM
Internall regulated alternator dusterbd Electrical 3 03-21-2007 09:27 PM
Internally Regulated Alt... Only Way To Go!!!!! hotrod389 Electrical 3 10-15-2006 06:41 PM
Changing from a external to a internal regulated alternator Warrant Electrical 11 08-21-2006 07:10 PM
