testing me? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2005, 08:05 PM
old69's Avatar
New Member
testing me?
I called shop to repalce the ring and pinion in my 8.2 10 bolt rear, and the guy asked what size the ring gear bolts were, and how many. Now i'm kinda new at this, so without pulling the cover i did some research and found out the size of the bolts are 3/8", but i dont know how many bolt are in the ring gear. Does that question sound funny, or is it a normal question? Any input would be helpfull. thanks. Just another thing its a posi,if that matters,.
Old 03-06-2005, 08:16 PM
OddRodder's Avatar
CORNFED and INBRED !?!
It sounds like he is trying to I.D. the rearend without seeing it. Judging by your screen name, do you have a 69' olds? If so, it probably has the heavier 8 1/2" rearend. B.O.P. started using it before chevy did because chevy was using the 12bolt in higher h.p. cars. I would just drive the car over to the guys shop, he should be able to tell which rearend you have if you are unsure.
Old 03-06-2005, 08:18 PM
I dun learned sumthin
Was your question how many bolts are in the ring gear? If so the number is ten if it is an 8.2 or an 8.5.
Old 03-06-2005, 08:22 PM
old69's Avatar
New Member
thanks
I know the name is misleading I have a 69 camaro, the guy hasent seen the car so thats probably what he was doing. Around here no-one really wants to do that kind of work, there's no speed shops or anything. He's just a local shop guy who says he can do it. Thanks for the replies.
Old 03-06-2005, 08:26 PM
Holder350's Avatar
Auto Parts Professional
The Ring gear is 8.2" in diameter and the number of bolts would be 10...you know "10 bolt".
I work in the parts buisness and the dude you talked to knew only what the computer toled him if all you needed was a price for a ritchmond gear it wouod be around $110
Holder350......
Old 03-07-2005, 01:25 AM
Holder350......
Just don't forget that GM axles arn't named by the # of ring gear bolts. Only on some of them do the # of ring gear bolts and the # of cover bolts match.
GM axles are named by the number of bolts holding on the cover.
FWIW I have a 14-bolt that only has 11 ring gear bolts because one of them is stripped
EPA certification and testing ckucia General Rodding Tech 2 12-17-2004 05:17 PM
testing hydraulic lifters... Sagacious Engine 7 09-28-2004 08:36 PM
Engine cradle testing stand Longboard Garage - Tools 3 04-20-2004 01:39 PM
Vacuum testing information western star Engine 1 01-03-2004 11:38 AM
testing troy-curt Hotrodders Site Suggestions and Help 0 06-15-2003 07:50 PM
