Testing Pertronix Ignitor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2007, 12:32 AM
hey all, i've got a 1970 skylark with a stock 350-2, except that installed a pertronix ignitor electronic ignition in the distributor. its been working great for the past year, bu recently the engine just went belly-up and died. i dont think it is a carburetor problem, because i know its getting fuel in the intake. my guess was the coil, but it was also recently replaced, and i checked it. it turned out ok, so now im thinking that maybe the pertronix unit failed. i really dont want to spend the $90 again, just to have the problem stay the same, and end up with an extra unit. is there a way to test and see if it is providing spark to the plugs?
thanks
Old 05-01-2007, 03:59 AM
Drive it Like u Stole it!
why dont you just hook a timing light up to one of the spark plug wires and try to crank the engine over... if the timing light blips, there's spark!
Old 05-01-2007, 04:14 AM
Wiki Edits: 31
yup, but pertonix ignitiors are known to croak like this, but they do have a 30 month warranty, so your good ither way
Old 05-01-2007, 04:36 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I had one fail on me just like that. You'd be better off installing an HEI. You wouldn't have to worry about getting stuck somewhere in the middle of the night.
Old 05-02-2007, 02:00 PM
thanks guys, but it turns out the bolt holding the distributor in place was loose, and it turned about 45 degrees around, throwing the timing way off. thanks for the help though
Pertronix 1181; 1181LSC; and 91181 rapsag Electrical 48 05-22-2011 10:40 AM
Pertronix 1181; 1181LSC; and 91181 rapsag Introduce Yourself 3 01-04-2006 07:40 PM
testing turn signal socket??? classic keith Electrical 11 04-11-2005 04:57 PM
anyone have pertronix install instructions & tech help? dbuff Engine 3 10-18-2004 10:39 AM
Mallory YL & Ignitor Sweden Engine 2 06-05-2003 03:43 PM
