Testing Starter Solenoid - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2009, 11:11 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I have a starter solenoid for a 1980s John Deere 108 I'm fixing... not sure if it's the key switch, solenoid, or what. I hooked battery straight to starter and it cranks, not sure if there's spark or not. (is there a foot safety switch on these?)
Anyway, how do you test the solenoid? (2 large posts, for + battery cable and starter cable hookups, and one small connector (key switch + ? Is the 'mounting plate' the ground?) I didn't hear a 'click' when I turned the key. The key switch and solenoid are below the battery, and it's a really tight fit as the 'heavy duty' battery is really about 1/2 inch too tall to fit in there smoothly (I have to pull back on the dash a little and squeeze it in, it takes about 5 minutes haha) so I'd rather not deal with putting the battery in and out again to see what works and what doesn't.
Thanks,
matt
Old 09-30-2009, 02:15 PM
jumper wire on the small lug from switch to battery side hook up .
no click or turn over , check that solenoid has good ground .
heavy jumper cables made from welding leads , you can put the battery somewhere else and try .
good luck breaking ground
Old 09-30-2009, 03:00 PM
Wiki Edits: 7
I'll give that a shot after work tonight! I gotta go to work, thanks
-Matt
Old 09-30-2009, 03:19 PM
302 Z28's Avatar
Most of those old solenoids can be rebuilt...of sorts. If it can be taken apart you will find a large copper disk attached to the rod that moves in and out of the coil. If that copper disk is worn it can be turned around exposing a clean face to the contactor.
Vince
Old 10-01-2009, 12:09 AM
Wiki Edits: 7
Vince
good tip
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
Ford solenoid on Chevy starter ??? Augusto Electrical 4 08-13-2009 12:59 PM
Does this seem like a starter solenoid problem? fastrehotrods Electrical 5 02-15-2006 05:26 PM
ELECTRICAL or Starter PROBLEMS? Jacks77 Electrical 29 08-30-2005 12:18 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 05:48 PM
