Tex Racing T101 Nascar gearbox? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2011, 12:38 PM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
Wath oil to use?
Old 07-18-2011, 02:24 PM
RippinRon's Avatar
I searched and found to use a good 75-90 synthetic. You may need a cooler, straight cut proshifted gears make a lot of heat. This is track only right?
Old 07-18-2011, 04:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Scandinavian
Wath oil to use?
↑X2 IMO, 75-90 is a good recommendation.
I'm not sure where you are w/the trans- if you have it already, etc. There are considerations w/the front bearing retainer, for instance; some are short for hydraulic TOB and others are the "normal" longer type for the TOB to slide on. The case is Mg, so care needs to be used torquing the fasteners throughout. It can be shifted w/o the clutch. The gears are straight cut so it's loud as hell. Actually a race-orientated piece, although some guys do use them on the street.
And they will wheel hop like a bandit if you get carried away downshifting it w/o the clutch. Seems a lot of guys like the Long shifter.
Old 07-19-2011, 05:35 AM
its fore a drift car
Old 07-19-2011, 05:37 AM
Thanx fore the Answers!
Summit Racing Street & Strip® Premium Racing Oil V8 Super Beetle Hotrodding Basics 7 10-08-2009 03:34 PM
Gearbox Help camaro1212 Suspension - Brakes - Steering 3 11-17-2008 11:12 PM
What gearbox? JonasB Transmission - Rearend 0 01-03-2007 09:15 PM
Priming a gearbox? 69ChevelleAddict Suspension - Brakes - Steering 4 08-10-2006 02:52 PM
Which gearbox w/ 550hp???? ehacker01 Transmission - Rearend 5 05-19-2004 01:12 AM
