Yeah, all those producst will work. Just remember they are all a 1K product-basically a lacquer type design so give it plenty of dry time before applying your paint-follow the directions on the can. None of them are comparable in quality to what the OEM used.
Another option if you're just looking for texture is to load your gravity feed gun with a urethane surfacer and turn the airpressure down so it spits, spit the primer on to the desired texture where needed then adjust the pressure up and lay on one light thin wet coat, allow to cure then scuff with a scotchbrite then paint. Sounds crude? It works in a pinch... Bob
