TH-200C Kickdown? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2005, 04:59 PM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
TH-200C Kickdown?
Its a 3 speed auto TH-200C transmission in my camaro.. I don't have my kickdown cable mounting bracket made yet.. But would it hurt it to drive it without the cable hooked up in the time being? Just as long as I manually shift. I know the cable controls the shift points and all but wasn't sure if it'd burn up the transmission without it hooked up..
Old 05-08-2005, 06:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It is not a kick down cable.... it is a TV cable . TV = throttle valve
it must hooked up and adjusted correctly to avoid burning the tranny up
Old 05-08-2005, 07:49 PM
I thought the Th-200 4R and the TH700R4 were TV cables and the 200, 350, and 400 were kick down cables..
Old 05-08-2005, 08:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that shows you have incorrect information.
The 350 is the only unit with a detent cable that if unhooked the tranny will not burn up. The t-400 does not have a cable. These two trannys have a vacuum modulator on them
th350 + kickdown + problem sbc350 Transmission - Rearend 15 01-26-2004 01:08 PM
th350 kickdown ajustment jon_volk Transmission - Rearend 5 01-16-2004 06:17 PM
a/t kickdown cable adjustment maddmaxx Engine 4 10-27-2003 08:04 AM
TH350 kickdown cable andybird Transmission - Rearend 4 07-25-2003 06:54 PM
Adjusting Kickdown horvath Transmission - Rearend 4 05-17-2003 04:14 PM
